Vending Machine...
E
Esma
my project designing a vending machine that sells a candy for 40 cent. it accept olny 5 cent(N) and 10 cent (D). and the candy i wrote this code for this but i couldn\'t write a testbench to see waveform Can you help me please
library ieee;
use ieee.std_logic_1164.all;
entity vending_machine is
port (
CLK, RESET: in std_logic;
N, D: in std_logic;
output: out std_logic;
change: out std_logic_vector(5 downto 0)
end vending_machine;
architecture process_3 of vending_machine is
type state_type is (s0, s1, s2, s3, s4, s5, s6, s7, s8, s9);
signal state, next_state: state_type;
begin
process (CLK, RESET)
begin
if (RESET = \'1\') then
state <= s0;
elsif (rising_edge(CLK)) then
state <= next_state;
end if;
end process;
process (state, N, D)
begin
case state is
when s0 =>
if N = \'0\' and D = \'0\' then
next_state <= s0;
output <= \'0\';
change <= \"000000\";
elsif N = \'0\' and D = \'1\' then
next_state <= s1;
output <= \'0\';
elsif N = \'1\' and D = \'0\' then
next_state <= s2;
output <= \'0\';
end if;
when s1 =>
next_state <= s0;
output <= \'0\';
change <= \"000101\";
next_state <= s2;
output <= \'0\';
next_state <= s3;
output <= \'0\';
end if;
when s2 =>
next_state <= s0;
output <= \'0\';
change <= \"001010\";
next_state <= s3;
output <= \'0\';
next_state <= s4;
output <= \'0\';
end if;
when s3 =>
next_state <= s0;
output <= \'0\';
change <= \"001111\";
next_state <= s4;
output <= \'0\';
next_state <= s5;
output <= \'0\';
end if;
when s4 =>
next_state <= s0;
output <= \'0\';
change <= \"010100\";
next_state <= s5;
output <= \'0\';
next_state <= s6;
output <= \'0\';
end if;
when s5 =>
next_state <= s0;
output <= \'0\';
change <= \"011001\";
next_state <= s6;
output <= \'0\';
next_state <= s7;
output <= \'0\';
end if;
when s6 =>
next_state <= s0;
output <= \'0\';
change <= \"011110\";
next_state <= s7;
output <= \'0\';
if RESET = \'1\' then
next_state <= s0;
output <= \'1\';
else
next_state <= s8;
output <= \'1\';
end if;
end if;
when s7 =>
next_state <= s0;
output <= \'0\';
change <= \"100011\";
next_state <= s0;
output <= \'1\';
else
next_state <= s9;
output <= \'1\';
end if;
next_state <= s0;
output <= \'1\';
else
next_state <= s9;
output <= \'1\';
end if;
end if;
when s8 =>
next_state <= s0;
output <= \'1\';
else
next_state <= s8;
output <= \'1\';
end if;
end if;
when s9 =>
next_state <= s0;
output <= \'1\';
else
next_state <= s9;
output <= \'0\';
end if;
when others =>
next_state <= s0;
output <= \'0\';
end case;
end process;
end architecture process_3;
library ieee;
port (
N, D: in std_logic;
begin
begin
state <= s0;
end if;
end process;
begin
case state is
when s0 =
next_state <= s0;
output <= \'0\';
next_state <= s1;
output <= \'0\';
next_state <= s2;
output <= \'0\';
end if;
when s1 =
next_state <= s0;
output <= \'0\';
next_state <= s2;
output <= \'0\';
next_state <= s3;
output <= \'0\';
end if;
when s2 =
next_state <= s0;
output <= \'0\';
next_state <= s3;
output <= \'0\';
next_state <= s4;
output <= \'0\';
end if;
when s3 =
next_state <= s0;
output <= \'0\';
next_state <= s4;
output <= \'0\';
next_state <= s5;
output <= \'0\';
end if;
when s4 =
next_state <= s0;
output <= \'0\';
next_state <= s5;
output <= \'0\';
next_state <= s6;
output <= \'0\';
end if;
when s5 =
next_state <= s0;
output <= \'0\';
next_state <= s6;
output <= \'0\';
next_state <= s7;
output <= \'0\';
end if;
when s6 =
next_state <= s0;
output <= \'0\';
next_state <= s7;
output <= \'0\';
next_state <= s0;
output <= \'1\';
else
next_state <= s8;
output <= \'1\';
end if;
end if;
when s7 =
next_state <= s0;
output <= \'0\';
next_state <= s0;
output <= \'1\';
else
next_state <= s9;
output <= \'1\';
end if;
next_state <= s0;
output <= \'1\';
else
next_state <= s9;
output <= \'1\';
end if;
end if;
when s8 =
next_state <= s0;
output <= \'1\';
else
next_state <= s8;
output <= \'1\';
end if;
end if;
when s9 =
next_state <= s0;
output <= \'1\';
else
next_state <= s9;
output <= \'0\';
end if;
when others =
next_state <= s0;
output <= \'0\';
end case;
end process;
The bit that is important in the test bench is this:
port (
N, D: in std_logic;
You need to treat your design as a component in the test bench. Write code to drive the clock, the N and the D inputs as you choose. You can examine the outputs manually in the simulator, or, if you wish to analyze the design carefully, you can write code to verify the outputs automatically. The statement to assist with this is:
assert(exp);
Where exp is an expression that should evaluate to TRUE. If not, the assert statement will print to the simulation output. You can combine assert with report to give a specific text output indicating exactly what is wrong, including the value of the thing being tested.
Rick C.
- Get 1,000 miles of free Supercharging
- Tesla referral code - https://ts.la/richard11209
